Home > Technical > Calling Paint Experts!! Help Identifying Paint color / code
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends. So my 1989 Defender 90 does how have the Color stamped on the VIN plate under the hood. My car has had paint work done before I bought it, and my hope was they use the original paint color, which based on my visual observation looks to be true...?
Is there any way to identify Paint color via Decoding the VIN#? I did look up a VIN decoder and it would appear the answer is no.
That being said I have tried to dig up possible white colors that Land Rover used.
- For 1988 - 1990 the closest white appeared to be Ivory/Chamiox 354 (thinking it is this)
- Another possibility could be Chawton White 603 but the earliest was 1998
Thank you for the help
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #958454 15th Jul 2022 6:23pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Shiny! Looks lovely...however, my advice would be visit a proper body shop and ask them to use a colorimeter or spectrophotometer to give you a proper colour code. When the local smart repair guy came to do some painting on my 110 he did just that and told me the Land Rover code and the result from his spectrophotometer disagreed, not by a lot but enough to be noticeable. Paint will fade and oxidise especially if you live in a sunny climate, so unless you plan to paint the whole thing it would be foolish to assume that the old original colour will match even if you did pick the right one.
Post #958456 15th Jul 2022 6:59pm
Dinnu
I have a 1988 90. It took me more than 20 years to figure out the true colour. I always thought it was Marine Blue... but it was (still is) Shire Blue, a colour that I never found in any brochure.
When I was almost sure that it was Shire blue, I had a paint center mix a small batch, sprayed a sample and compared to areas that where original factory and not oxidized with UV. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958457 15th Jul 2022 7:02pm
Dinnu
Forgot to mention... lovely 90 Bow down 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958458 15th Jul 2022 7:03pm
kenzle8a
Bit like my chums 1986 110, it’s one of those things the colours do vary a touch depending on who supplied them or what mood they might have been in
Post #958478 15th Jul 2022 9:51pm
RichardL
paint code chawton white
NAL CHAWTON WHITE 1995-2002 BLVC 1218
Post #1030990 8th Apr 2024 8:52pm
