Home > V8 > 50th anniversary exhaust route
Page 2 of 2 <12
V8GPC
is the discovery 1 V8 cross member the same?
https://www.ebay.co.uk/itm/Land-Rover-Disc...SwVL5a~n-N
https://www.ebay.co.uk/itm/LAND-ROVER-DISC...SwEzxYPDYt
https://www.ebay.co.uk/itm/LAND-ROVER-DISC...Swt0FZCIq-
I have a 50th and can take some measurements for hole spacing etc.
It may be worth the £24-£30 risk above.
Post #732105 1st Oct 2018 6:40am
Romadog
If you look at the shape of the chassis mounting plate it's not quit square is it?
Basically all you do is weld plate to it to make it square then add an inch or so on the bottom to give the extra height required.
If you can't do yourself then get a local fabricator to do it. Cost me £30 to get it done. I just fitted and drilled holes.
Done it on my 110 and now my 90.
Post #732119 1st Oct 2018 8:44am
oneten110
It is done. All fitted and working. Even fitted without too many problems.
Post #744230 5th Dec 2018 6:39pm
Page 2 of 2 <12
