Home > Group Buys > Genuine Landrover TD5 Rev Counter |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6491 |
Something looks like it went wrong with PayPal but your order and payment have come through fine 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Jan 2017 2:30pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1336 |
Hi Martin, that's spot on, but correct me if I'm wrong, but 30cm of wire supplied isn't enough to go to the back of the rev counter from the ecu? Cheers |
5th Jan 2017 3:32pm |
Correct - it's not a full fitting kit (you would also need power and illumination and ground for the rev counter).
It's simply to give a connection to the rev counter signal on the ECU plug. I could put together a full retrofit wiring kit but it would be more than £1.60 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Jan 2017 3:53pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Just caught up with this. I'll give Dan a call on Monday
7th Jan 2017 5:39pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 706 |
Hi Martin, do you know if its possible to take the power, illumination and ground from the clock assuming I don't plan on reusing it? |
11th Jan 2017 1:24pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
rev counter received - many thanks Dan and pj for organising
I have seen full wiring kits for td5 rev counters from Croytec for £20 if that helps anyone? cheers |
12th Jan 2017 3:33pm |
You can take ground and illumination from the clock. The power for the clock is permanent so you need to borrow an ignition switched source from another gauge. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
12th Jan 2017 3:46pm |
Croytec's "loom" appears to be 5 spade connectors on a short piece of wire each. Not a plug-and-play loom? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
12th Jan 2017 3:49pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Is there a 'rule of thumb' as to which vehicles will have the rev counter wiring in place behind the instrument panel and which will not? 2005 Td5 | 90 Station Wagon | Tonga Green
18th Jan 2017 5:13pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Check pin 19 on your black ecu plug if has a grey wire then 👍 Just gotta find it behind the clocks 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
18th Jan 2017 8:28pm |
Pin 19 is connected for vehicles with ABS so not always an indication it will be behind the clocks. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Jan 2017 10:54pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 220 |
Well it's ticked over the end date of 31 Jan , but within a Land Rover margin of timing
(Good excuse, was in Grampians, VIC) I'm in if this is still happening. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
17th Feb 2017 9:42pm |
Read earlier in the post as Dan has posted details for purchase 👍 2008 110 2.4 XS Utility (Hagrid)
17th Feb 2017 10:14pm |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 80 |
Bit late to this one but hopefully it is still open.
Any problems Dan just let me know. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
21st Feb 2017 12:12am |
