Home > Puma (Tdci) > VCV fuel valve |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Any one have any links where to buy replacement vcv valve?
21st Aug 2015 3:48pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
The Landrover part number is LR009837
The Ford part number is 1 514 885 The Denso part number is 6C1Q 9358 AB http://www.ebay.it/itm/FORD-TRANSIT-MK7-2-...7963407712 http://www.amazon.co.uk/Ford-Transit-Vapou...ds=1514885 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
21st Aug 2015 7:48pm |
Thank you Theater you are a star
21st Aug 2015 9:22pm |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 |
I too have a problem I believe from reading various threads is down to the vcv. I have found the denso part at £45 on fleabay but from the workshop manual you need to calibrate the valve with the ecm.
Further reading suggests that not all programming tools will do this. Can someone advise which tools can do this and also is it possible to have a LR dealer just do the calibration? Tommy 110 XS TDCi |
1st Sep 2015 7:38am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5668 |
As above, no for a nanocom, yes for faultmate, but it couldn't/wouldn't do mine, so had to take mine to Alive where they used Rovacom (if that's correct) which is what the main dealers use.
Andy |
1st Sep 2015 9:25am |
https://www.defender2.net/gallery/albums/u...VCV%20.pdf Marco
1st Sep 2015 8:00pm |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
IID tool can too, did it on a 07 a month ago.
Looking at the old VCV I could not see why it needed changing. Ticks over properly after changing it. "Rafiki" 2007 110 STW - Rolling rebuild. |
2nd Sep 2015 12:06am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The BAS2 RRC can also calibrate the VCV as well as do the pilot correction learning.
https://secure.bellautoservices.co.uk/stor...p-control/ |
2nd Sep 2015 9:06am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
You never can see a difference! It puts me off buying el-cheapo ones on Ebay etc since if someone packaged their old one in the box the new one had come in, chances are you'd never know. You'd just attribute any ongoing issues to some other fault. |
2nd Sep 2015 10:40am |
