![]() | Home > Maintenance & Modifications > McNally EGT/Boost gauge. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I have the EMS2 - awesome piece of kit: ![]() Click image to enlarge ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
OK, rub it in!.... Where did you get yours from/ how did you get in contact with them? I tried emailing (Twice) Landy Online Workshop- who are advertised as the main distributor- but never got a reply ![]() Also did you go for the gauge and 'fitting kit'? Glyn ![]() ![]() |
Glyn, I am in SA, and got via one of their resellers. try this email: shop@landyonline.co.za -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Naks where and how did you fix the EGT probe too the exaust manifold ?
Not sure, IIRC the installer drilled & tapped it before the turbo. You will have to drill a hole through the turbo heat shield as well. See http://www.landyonlineretail.co.za/worksho...ml?start=2 ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Looks like a top job.
I was not present, but nothing was removed, I assumed they just idled the engine -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Jay Member Since: 23 Apr 2012 Location: Veneto Posts: 27 ![]() ![]() ![]() |
Hi Naks I'm going to buy an EMS2 plus kit for 2.4 puma, and I need some advice for installation on my landy, can you give me some picture of your installation? for each sensor?where did you did go through the wire? have you made a thread for your work? thank you very much Jacopo Jay |
Jacopo, unfortunately I did not do the installation, so I cannot help you.
However, there is a detailed instruction manual on the Madman website: http://www.madman.co.za/index.php/engine-m...-cld-units Puma 2.4: http://www.madman.co.za/index.php/kits-men...ma-2-4-kit Puma 2.2: http://www.madman.co.za/index.php/hikashop...r-puma-2-2 And some YouTube clips from Madman, not specically for the Puma, but handy tips for installation: https://www.youtube.com/user/MadManAutomotive -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
thanks
already seen it.. but i'm searching other photo for make me an idea of the RIGHT work that must do Jay |
sorry buddy, I'm useless when it comes to DIY.
![]() I do know that the Earth must be really good, and to either remove the manifold before drilling. If not, drill while the engine is running. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
yes, I remove it ..or I faint with drill on my hand
