Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 31 of 32 <123 ... 303132>
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Blackwolf
When assembling I did pump too much grease in and push the shaft out !
Just need to be carful when it comes to greasing.
So just need to find a CV boot that has an ID of 80 X 40mm
Post #1023526 4th Feb 2024 12:08pm
MK
In theory, you would need to use a lathe to cut a "groove (?)" for both sides of the boot and fit some sort of clamp, etc. By then, it may be wiser just to fit an aftermarket solution (Time and funds dependendt). Puma 110" SW
Post #1023530 4th Feb 2024 2:26pm
Dinnu
Finding a CV boot with large diameter of 80mm should not be a problem. But a small diameter that fits on 40mm drive shaft would be. Perhaps you can carefully cut a smaller one along one of the bellows to get the 40mm shaft size.
The grooves are required on actual CVs to prevent the boot from coming out on a full steering lock. Probably would not be needed in this application.
But what was remarked and also confirmed about the hydraulic pressure of the grease pushing the shaft out is more worrying. Perhaps it is smart to think of a more positive locating of the shaft in its cup and not rely on the snap ring pressure only. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1023533 4th Feb 2024 3:20pm
spudfan
Ireland
2008 2.4 Puma still on original factory fitted shaft. 210,403 kms.
2011 2.4 also still on original shaft at 103,372 kms 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1024757 15th Feb 2024 1:43am
Learningasigo
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
2014
2.2 110 xs
Original shaft until Jan 2024
Failed at 80,000k
LOF fitted
Post #1029974 31st Mar 2024 8:42pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
2013 2.2 110 SW
Original shaft until April 2024
Failed at 99,000m
On the basis the first one lasted 99,000 miles, I decided to stick with a standard shaft, but
... wait for it, this is complete genius and will blow your mind! ...
with grease!
It cost me £80 for a lorry to move it & £600 for parts and labour.
Photos show the usual problems...
Post #1032137 19th Apr 2024 1:36pm
Dinnu
^^^^ it looks like the shaft spent most of its life not fully into the cup. You can see where the splines did not wear where the snap ring should had been. Maybe you would had got a few extra miles if it was properly assembled (or not?).
Edit: Seeing the last photo of the cup splines, it looks like Landrover installed it correctly as there is some wear on the inner part of the splines, but somehow the shaft came out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032142 19th Apr 2024 2:04pm
JPE
Thanks Dinnu, I had wondered whether that wear pattern was normal or not.
Perhaps its been apart before & not reassembled properly - ?
There are always so many mysteries to ponder when you have a defender.
Post #1032156 19th Apr 2024 4:28pm
MK
I have seen several cases where the adapter has made its way out of the female "cup". Puma 110" SW
Post #1032196 20th Apr 2024 12:30am
Ianh
To be fair, inadvertently making our way out of the female cup has happened to all of us at some time. Next time I will blame it on JLR Rolling with laughter Rolling with laughter Rolling with laughter
Post #1032198 20th Apr 2024 1:36am
MK
Rolling with laughter Puma 110" SW
Post #1032199 20th Apr 2024 2:34am
spudfan
Ireland
From my home mechanical experience, regarding the female cup. Up to a certain "milage" things fall out of the cup, after that they seem to flow out. Seems milage and age affects the rigidity and suppleness of the structure. Ah the old days when everything was a snug fit..... Whistle 1982 88" 2.25 diesel
Post #1032215 20th Apr 2024 10:22am
ralsim
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Santorini Black
2014
2.4 110 xs double cab
Original shaft until May 2024
Failed at 158,000miles
LOF heavy duty will replace it current daily defender puma 110 xs 2.4
Current Project Series I 1.6 2 door
past
landrover 110 1983 v8 stage 3 engine with ported heads, ported polished inlet manifold balanced crank, large trumpets, top hat liners large valves ported plenum with large butterfly sadly stolen
Post #1034933 16th May 2024 3:53pm
LJMARSDEN
United Kingdom 2006 Defender 90 Td5 HT Java Black
brilliant Rolling with laughter Rolling with laughter Rolling with laughter Luke Marsden
06 V8 1UZFE Defender 90
Instagram: https://www.instagram.com/defender__v8/
Post #1034934 16th May 2024 4:11pm
ralsim wrote:
2014
Failed at 1580,000miles
One-and-a-half MILLION miles ! Shocked I presume that is a typo?
Post #1034949 16th May 2024 6:25pm
