Home > Technical > Clock out if true |
It is unlikely that it is worth doing anything to repair the problem. I suspect it would be a destructive process to get to the hour hand and correct its position.
Three things then that you could do: 1) Live with it. 2) Replace with a like for like gauge. 3) Replace with a clock on another gauge such as the Check Temp 2. I went the latter number 3 route and fitted a tachometer in the place of the dash clock. |
2nd May 2024 2:30pm |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 288 |
Think it might be route two … @steve_overland on Insta.
110 expedition vehicle with pop roof |
2nd May 2024 2:44pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
Can't see option 1 working for Steve.
I have a spare one here Steve, exactly the same as yours , you could have a matching pair! Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd May 2024 2:50pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 808 |
If you turn it upside down, it should be correct again?
2nd May 2024 3:15pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2527 |
Texas, I have a strange issue with my clock, six months correct, then six months an hour different, then six months later it fixes itself…..
It’s a feature, I can live with it…. |
2nd May 2024 6:12pm |
Just what I need two that a wrong hahaha.... @steve_overland on Insta. 110 expedition vehicle with pop roof |
2nd May 2024 6:31pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 772 |
Strangely, and annoying for you, but the original dashboard clock in my 1994 300tdi is incredibly accurate and the fingers point to exactly where they should. The only time it ever needs altering is if I have had the battery off or twice a year for the clocks changing.
3rd May 2024 12:21am |
