Home > Technical > Radiator Fan Immediately On
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
New owner of a 2011 110 dcpu. On cold start the radiator fan starts with engine. Are they viscous and so should only kick in when temp reached or can there be a dodgy sensor somewhere. Would like to diagnose this myself. Any help appreciated cheers Phil.
Post #1033230 29th Apr 2024 11:46am
Ianh
As standard the fan will be a viscous fan , although someone could have replaced it with an electric fan. It’s easy to tell which one you have with the bonnet open, if not sure post a picture and members will confirm.
A viscous fan is a self contained unit, with no input from external sensors. In essence it uses a bimetallic coil, that when heated allows fluid to fill a gap between two plates that then causes the fan to rotate.
The fan can free rotate with engine running but if working properly does not engage more unless the airflow over the bimetallic coil reaches the right temperature.
From what you say , if it’s a viscous fan, it is working as normal.
This is well worth a read on the subject. https://www.defender2.net/forum/post754068.html
Post #1033239 29th Apr 2024 12:58pm
hank
Double check which fan is going.
The engine coolant fan is viscous.
The air conditioning condenser fan is electric - you can see this one behind the front grille > 110 XS Double Cab
> Instagram @simonlanemind
Post #1033240 29th Apr 2024 1:00pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
The viscous fan will always rotate with the engine but its basically just freewheeling until the hub locks up.
Post #1033256 29th Apr 2024 3:22pm
Phillywilly72
I don’t have air con and if the rad fan goes at full whack on startup, I suspect it’s seized. I’ll try the newspaper method first. Also will a viscous freely rotate if I hand spin it switched off and cold?
Post #1033266 29th Apr 2024 4:35pm
andy63
United Kingdom 2014 Defender 110 Puma 2.2 CSW Aintree Green
The fan may well make a bit of a roar at start up.. But it should revert to a quieter tone fairly quickly.. If there is fluid still in the coupling when you start it takes a few seconds for it to be forced back into the reservoir..
I'm sure this has already been mentioned but if you use a bit folded newspaper it should be possible to stop it rotating fairly easily when cool.. When warmed up and connected it will be difficult to stop if it's working properly.. I'm sure you could use a hot air gun to carefully connect the coupling by actuating the valve 👍
Post #1033269 29th Apr 2024 4:53pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just small detail - when the mechanical engine fan is on full power (with viscous clutch engaged), it sounds like a small helicopter, and with hot engine you will feel hot wind on your feet standing behind the car. Is is much more powerfull than standard electric fan. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1033357 30th Apr 2024 8:31am
