Home > Camping, Caravanning and Holidays > Tentbox owners with roof rack? |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 539 |
Using a roof rack with a roof tent is a bit of a waste because the tent fills the rack. Roof bars are all hat's needed and they weigh less; lower weight up top is a good thing.
However, if the supplied bolts are not long enough is easy to buy some longer ones https://accu.co.uk/ When I fitted the roof tent to my Defender I fabricated my own bars for stainless steel stock bar and purchased the required fixings from the above link. |
23rd Apr 2024 11:12am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
i have had my tent fitted to my rack which si the same and used a big sandwich washer. no problems.
helps having battery ratchet to tighten though as it is a little tight |
23rd Apr 2024 11:48am |
