Home > Faults & Fixes (L663) > Clicking/Ticking Noise Whilst Turning Left Or Right And Full |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 155 |
Good morning everyone,
This is exactly what happens to me: Clicking/Ticking Noise Whilst Turning Left Or Right And Full Lock At Low Speeds. in my case, in particular in reverse when parking, turning the steering wheel all the way to the left. Has this happened to any other forum user? Click image to enlarge Click image to enlarge I saw there is a bulletin: https://www.tsbsearch.com/Land-Rover/SSM75779 they say that the four bolts that hold the front hub need to be replaced (unfortunately they are very difficult to replace........, they are very hard and difficult to access), it seems so unlikely to me that these bolts could be the cause of the clicking noise in discontinuous reverse. Thank you Marco |
16th Nov 2023 7:08pm |
hi, thanks for the reply,
the problem is this clicking noise, not a shock, it is a light noise that is barely audible (my wife can't hear it...), it can be heard even with the car stationary, turning the steering wheel to the right and left. I think it could be an incorrect tightening of the wheel hub bolts as reported in the technical bulletin. |
22nd Nov 2023 7:52am |
update, problem solved with the replacement of the four hub bolts, curious that when driving the car the noise seemed to come from the left side (driver for me), raising the car and removing the bulkheads the noise was on the right. replaced the right hub bolts, noise disappeared.
Marco |
24th Nov 2023 12:25pm |
DazzlerAU Member Since: 21 Jan 2024 Location: Sydney Posts: 1 |
I have this same issue, front right side. Dealer couldn't isolate it at my last service. Is this a big job? Maybe I should show them the TSB?
16th Feb 2024 9:34pm |
hi, I solved it.
to make a diagnosis I put the car on the lift with the platforms, I tried to turn the wheels and identify the origin of the noise. Click image to enlarge First I changed the hub bolts, it's a difficult job, it requires a very high tightening torque. Despite this, there was still a click when I turned the wheels to the right and left with the car stopped. I looked for other solutions, in particular I replaced these lower protection clips as you can see, when you rotate the wheels they probably flex and make noise, changed them all, tightened the bolts well, noise disappeared. I inserted anything else I found, please tighten the wheel bolts in star order and to the recommended torque. Marco Click image to enlarge Click image to enlarge Click image to enlarge |
17th Feb 2024 9:06pm |
were you able to solve it? Marco |
21st Apr 2024 8:19pm |
