Home > Wheels & Tyres (L663) > 20” L322 Range Rover wheels on a Defender?
DrRob
Does anyone know if the 20” rims for the later 6 pot brembo calipers on an L322 Rangie will fit a D300 Defender that has the bigger calipers?
My thought process is to invest in a cheap 20” rim with a cheap tyre as the spare under a wheel cover…If it got nicked then no impact on the wallet etc.
If nobody knows then I’ll experiment and let you all know. New 90 on order for delivery in May 2024. D300 X-Dynamic HSE in Eiger
2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory interior and clear glass = "Rory" Will be up for sale in Spring 2024
1974 Series 3 Lightweight = "Millie"
Series 2A V8 Lightweight - gone
1952 80" - gone
1949 80" - still in family since 1975
Post #1032062 18th Apr 2024 8:31pm
stevemfr
France
L322's have a much greater positive offset - like 2cm worth - than the L663. You'll need to run spacers. Depending on the wheels I'd look at 25mm or so. But you'll also need to make sure the overall tire diameter is close or, in the case of a flat, you'll be risking much more than the cost of a stolen wheel after only a few miles.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1032197 20th Apr 2024 1:02am
DrRob
Ok. Thanks for the info. I’ll not bother investigating any further New 90 on order for delivery in May 2024. D300 X-Dynamic HSE in Eiger
1952 80" - gone
Post #1032216 20th Apr 2024 10:28am
