Home > Technical > LOF Clutch Assist Spring |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2008 |
Where do you fit the grease nipple then?
11th Mar 2024 4:53pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3219 |
See this: https://www.defender2.net/forum/topic22839.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
11th Mar 2024 5:00pm |
Thanks, I’ll get a grease nipple and try it.
11th Mar 2024 5:50pm |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 75 |
Did mine today.. thought I’d be in the 20 camp…
Turns out.. 2.5 hours..! The reason… the spring on one side didn’t fit in the bush! So after 2 hours and the standard expletives, cut knuckles etc, I knocked out the new offending bush and lined it up on the spring. Turns out it fitted one side, not the other! Too much LOF paint! Quick scrape off, fits a dream, 2 cable ties, fitted in literally 5 minutes! Thanks LOF - quality control Take the tip.. check it all fits before dropping to your knees! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
17th Apr 2024 5:24pm |
Fitted the grease nipple too Shafski
17th Apr 2024 5:25pm |
Quick update..
Drove her today.. first time since fitting.. OMG! The difference is night and day.. Those who ask.. PUMA 2.2.. is it worth it.. YES!!! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
19th Apr 2024 6:19pm |
