Home > Tdi > Coolant fluid for a 300TDi |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 510 |
Mine runs on pink. You need to match it to whatever is in there at the moment, what colour is yours running at mo?
31st Aug 2020 11:14am |
Seabreeze Member Since: 23 Mar 2016 Location: Suffolk Posts: 47 |
Mine is definitely pink!
31st Aug 2020 11:41am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3998 |
Apparently, colour is not a reliable indicator of the type of coolant in your system.
https://www.opieoils.co.uk/t-car-motorbike...ained.aspx 2007 110 TDCi Station Wagon XS |
31st Aug 2020 12:10pm |
OK, so I guess it is back to the hand book definition: " Use an ethylene glycol based anti-freeze (containing no methanol) with non-phosphate corrosion inhibitors suitable for aluminium engines....."
31st Aug 2020 12:20pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
If you can afford, drain radiator and block, flush with clean water and then fill with correct spec. That should give you complete peace of mind Defender 90XS SW
31st Aug 2020 6:22pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10545 |
I use to have the pink stuff and was told it was no good for my engine (300 Tdi ) it had not been in for to long, so the system was flushed out and now i have a very dark green/blue stuff, right for my engine 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
31st Aug 2020 9:29pm |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 230 |
I recently had the same dilemma, as has been said colour is not a definite indicator of type. As far as I could work out it is a choice of OAT based or Non-OAT based. The main difference being an OAT based coolant will last longer, typically 4 years before needing changing, whereas a Non-OAT based coolant needs changing every 2 years and was used in older engines.
As I understood it there was or is a school of thought that OAT based was not ideal on older engines due to issues with some seals. To be honest I never really could find a definitive answer so I have opted for the Non-OAT based solution and change it every 2 years. Its not a big job and I figure giving the coolant system a good old clean every couple of years is no bad thing anyway. In the end I chose this; Bluecol Antifreeze 2 Year 5l - BLA005. Not a very scientific approach I am afraid but a pragmatic one for me |
31st Aug 2020 9:36pm |
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 |
Same for me - so many opinions and information out there, it had pink, I went with what the manual said - happy to keep an eye on it and do it again. Think it was comma G40?
31st Aug 2020 10:03pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
Ethylene glycol is the stuff. Usually blue but not always.
Mo The Land Rover 90 - Many are called, few are chosen. |
1st Sep 2020 9:37am |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
I use this in my Defender 300tdi
5th Sep 2020 9:50pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 392 |
My ROW spec 2006 300Tdi came with the pink OAT stuff from the factory (as did all the others) so that's wrong - they are quite happy with either just don't mix the two! I think they moved to using OAT at the same time the Td5 came out, presumably to simplify things on the production line where they were building Tdi and Td5 alongside each other. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
6th Sep 2020 2:13pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1542 |
TDI uses the regular blue stuff as above
td5 oat red/pink coolant then you have purple and green for other makes like volvo...go figure. as long as you dont mix the different types you will be fine. just keep the strength correct. |
6th Sep 2020 7:44pm |
Wolfie831 Member Since: 19 Feb 2021 Location: Derbyshire Posts: 21 |
The issue with OAT coolants is when you may have upgraded to Silicone hoses, the Organic compounds breakdown the silicone over time and they WILL eventually fail. Only IAT (Blue) coolant is safe for use with the 300Tdi engine fitted with upgraded hoses. |
12th Apr 2024 10:53am |
Yes that is why i changed from pink to blue as it started to delaminate the silicone hose from the inside out 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
15th Apr 2024 9:07pm |
