Home > Technical > fitting a steering damper
Stevemartin437
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hi all
i have a 2015 90 and want to upgrade my steering damper for something better maybe the OLD MAN EMU NITROGEN STABILISER.
Is this just a like for like change over, something i can do myself ( very ltd capability).
Anything i need to watch for if i do myself?
Thanks
Post #1030584 5th Apr 2024 8:36am
X4SKP
Hello Stevemartin437
Yes.. simple DIY Project.
In principal, I did exactly this Land Rover OEM to OME, I used the Land Rover Washers
on the OME Steering Damper as they were a better thickness and fit.
However maybe I was unlucky with what was claimed to be a rare failure...
https://www.defender2.net/forum/topic83242-75.html
Good luck (and keep your receipt)... Thumbs Up SKIP
Post #1030588 5th Apr 2024 9:20am
Chicken Drumstick
Re: fitting a steering damper
Stevemartin437 wrote:
Hi all
Thanks
Better than what? What is wrong with your current steering damper that you think will be improved by an upgraded one?
As for fitting, about as easy as a spannering job gets.
Post #1030619 5th Apr 2024 12:36pm
Chicken Drumstick
What was the failure? I had a quick flick through, but couldn't see anything specific on the link.
Post #1030620 5th Apr 2024 12:38pm
Andrew95
United Kingdom 1997 Defender 110 300 Tdi SW Corris Grey
Hi all
Thanks
Very easy job, just unbolt the old and re-bolt in the new. No real tricks or anything to watch out for. If you find the pin end turns when your undoing it you can use a pair of stilsons to hold the damper in place.
Post #1030624 5th Apr 2024 12:58pm
X4SKP
Hello Chicken Drumstick
Scroll down to around 1/2 way on Page 6 of my SKIP'S 90110 Diary
Very much a spontaneous purchase decision (which isn't like me) when I was experiencing a slight
steering wobble. In retrospect even if the increased performance claimed by the OME Damper is correct, unless the original Damper was faulty this isn't the 'best practice' way of resolving my 'minor' issue. After checking all Steering Joints to find nothing I just ordered one. For me a new set of tyres and rebalancing sorted everything, I probably could have got away with just rebalancing (at £80) but jumped to new tyres as their time wasn't far off.
Oil Seal issue with OME Damper... Shocked
When it was off the Defender and compared with the original, which I had retained, the difference
was clear, 'interestingly' I couldn't say that I noticed the failure of the OME on the Defender...
as she runs so true now... Thumbs Up
The Land Rover Damper, from my limited experience, is probably fine for most under normal conditions. SKIP
Post #1030646 5th Apr 2024 2:37pm
