Home > Td5 > Defender Td5 - Front left brake not working, oil everyone
JoshCox
South Africa 2000 Defender 90 Td5 HT Alaska White
Hi Everyone
I own a defender Td5, 90 2000 model.
Recently I found when I braked the car pulls wildly to the right so I went to look at the front left brake.
It has been getting progressively worse and the brakes are struggling to hold the car on a hill.
The brake calliper, disk and inside of the wheel arch are covered in oil/grease. It doesn't look anything like brake fluid, and the reservoir of the brake fluid is still pretty full.
I'm not sure where the grease/oil are coming from, and what kind of fix I am looking at?
Any help would be greatly appreciated
Josh
Post #1028862 21st Mar 2024 4:15pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
First of all you'll need to work out where the oil or grease is coming from probably a hub seal or swivel seal leaking and getting thrown around.
When you say holding on a hill do you mean on the hand brake or holding the brake pedal down? 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1028930 21st Mar 2024 11:09pm
JoshCox
With the brake pedal it struggles to hold on a relatively steep hill
Post #1028952 22nd Mar 2024 8:52am
rustandoil
Defender brakes are actually pretty good.... Sounds like you need to do a complete inspection and overhaul of the brake system.
Post #1028953 22nd Mar 2024 9:02am
CanDef
Brakes stop the car with friction. Lubricants reduce friction. Check out the leak first. Degrease the area with brake wash and try it. Be sure that its not a brake fluid leak before driving. Could be dangerous.
Post #1030358 3rd Apr 2024 1:36pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Re: Defender Td5 - Front left brake not working, oil everyon
JoshCox wrote:
Hi Everyone
Josh
The tell-tale sign will be if the brake fluid level has dropped. If it hasn't you're looking at axle/hub oil seal or swivel seal. As has already been mentioned if you can eliminate the brake fluid leak you must clean everything and replace contaminated brake pads. Check the front axle oil level as this is fairly easy to do, if it's very low suspect oil seal. Checking the grease in the swivel is harder.
Good luck and be careful.
Post #1030457 4th Apr 2024 9:34am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Inner hub seal gone.
Post #1030460 4th Apr 2024 9:53am
