Home > Td5 > Slickshift fitted today |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2082 |
The allen bolt is a bit of a big. I had my impact driver on it with a Hex+ bit in being very careful not to strip it.
Could be that your cup is worn and needs replacing. You can get new turrets which arent very expensive tbf. Instagram @defender_ventures Empire Tuning - Agent |
30th Mar 2024 6:05pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 104 |
I think I’ll give it another go - trying to get that Allen bolt out so I change the sleeve (blue in the new kit). Something is telling me that the bias springs were doing at least something with the old set up. I’m wondering if the new kit does need to be fitted as a set. The video fitting was a few years ago I think, so maybe something has changed and using the old sleeve won’t give the bias springs enough tension? If it doesn’t work, I haven’t lost anything and will have to cough up for a new turret.
Any further tips for removal of the Allen bolt whilst in the car, not on a bench? Heat? Long bar of some home made design, penetrating fluid? Cheers. |
31st Mar 2024 10:10am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
Heat directly on the grub screw. Its loctite permanent on there. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
31st Mar 2024 4:38pm |
Cheers 👍
31st Mar 2024 6:48pm |
Hi all, just thought I’d update on the slick shift. I managed to get the grub screw / Allen bolt out with very little fuss using a 5mm? Hex bit with my standard socket set. It came out before I got the heat gun or blow torch out.
I had a look at the gear selector turret / housing new replacements and although I might be wearing the rose tinted specs, the new ones don’t look significantly different (I’m talking about the slots). Looking at one of my photos, the adjusting bolts won’t ever be doing much as the spring doesn’t really start pressuring the side tabs / pivots on the selector ‘shaft?’ Are the bias springs out of shape? Click image to enlarge Click image to enlarge |
1st Apr 2024 8:14pm |
New one
1st Apr 2024 8:33pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
They should do. The pins on the selector yoke sit quite high up in the slots. This one is well out of adjustment but shows the principle.
My yolk sat way down lower than that, although from your photo it looks as though it’s in first gear or just left side of neutral? I hope when I get back out there it is the new seat / bush that will raise the yolk up.
1st Apr 2024 11:31pm |
[quote="Retroanaconda"]They should do. The pins on the selector yoke sit quite high up in the slots. This one is well out of adjustment but shows the principle.
I can confirm that fitting the new blue bush / sleeve made all the difference. Now is fine ! 👍 Hope it helps others. Thanks for advice / help, really helps and motivates us novices to try things ourselves and begin to learn about these old girls. |
3rd Apr 2024 8:42pm |
