Home > Td5 > MAF Sensor
vipergreen
 2003 Defender 90 2.5 TD PU Oslo Blue
MAF Sensor
Ok I need some educating.
I’ve had a long standing black smoke issue which I am finally addressing.
I’ve just changed my Intercooler and the smoke reduced,,, a bit.
Nanocom says at idle the MAF is about 45, so I think a bit on the low side. Floor it whilst stationary and it jumps to about 330 then settles down to about 280.
Pulling the plug on the MAF seemed to give a bit less smoke.
I removed the MAF completely and no smoke.
So maybe I’m stupid but can I simply delete the MAF by extending the hose to the air filter ?
The EGR has already been deleted.
Thanks
Post #1030244 2nd Apr 2024 6:42pm
NickMc
You should have about 60 kg/hr at idle. Get a good quality MAF sensor (beware eBay fakes in genuine boxes and aftermarket junk] and try cleaning the MAP.
https://bellautoservices.co.uk/store/td5-air-flow-meter/ Available here and how to test it too.
Post #1030304 3rd Apr 2024 1:55am
