Home > Technical > need help identifying part number |
frogg Member Since: 17 Mar 2024 Location: usa Posts: 3 |
It looks like the clear plastic part might be MWC9917?
"LAND ROVER DEFENDER 90 110 130 SNAP SACK RETAINER CLIPS SET"? Except MWC9917 is 16mm. The depth of these appears to be 13mm. There appears to be snapsac sealing sleeves of different depths: "Snapsac' sealing sleeve, for 8.5mm panel hole , depth 13.7mm. General application" (12288P) but what is the fir tree portion? |
17th Mar 2024 8:50pm |
...I took a chance and ordered MUC3186 ( trim clip )
It is perfect in every dimension EXCEPT the distance between the head and the base of the trim clip. MUC3186 is 0.75mm wide, while the mystery part is 1.5mm wide. Click image to enlarge Does anybody know these trim clip part numbers? |
30th Mar 2024 9:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19658 |
Not sure about part numbers but possibly try eBay U.K.
www.eBay.co.uk Usually most things will be on there, if you still canβt find anything in detail try asking the seller on there for dimensions? Sometimes part nos are updated also. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
30th Mar 2024 10:19pm |
