Home > In Car Electronics > Hazard light bulb
22900013A
Hazard light bulb
It appears the bulb has failed in my hazard switch. The power lead snapped recently which I repaired, but now it seems the bulb has gone. The switch does not light up with the headlights on, nor flashes when pushed.
I can only see one tiny build that pops out when I turn it, is this the only light? And where can I source a replacement? Could anything else make it not work? I can see no damage to the wiring. The switches are stupidly expensive to replace. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #1029694 29th Mar 2024 1:56am
rustandoil
It's possible to dismantle the switch and fit a new bulb, Iused a "Scalextric" bulb sourced from Ebay... Only because I couldn't at the time find "grain of wheat" bulbs used in model railways.... It's a fiddly job if i remember but doable with care, good luck 🤞
Post #1029698 29th Mar 2024 7:47am
Martin
Site Admin
There are a few threads on here with the part number for the bulb Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1029701 29th Mar 2024 8:32am
22900013A
I tried searching but the eBay links were all old and no longer worked. I think I need stc1205? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1029710 29th Mar 2024 9:57am
22900013A
If seems to come apart easily enough, I just the replacement bulb. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1029711 29th Mar 2024 9:58am
Martin
Site Admin
Luckily you won’t get ripped off on EBay then. The price is bad enough without the markup eBay sellers add.
STC1205 is the correct part  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1029721 29th Mar 2024 10:37am
