Home > In Car Electronics > WTF are all these wires and connectors?
Grenadier
Whilst rooting around the engine bay on 'other matters', I came across the following selection of connectors and wiring stuffed under the driver's side wing. Does anyone know what they are all for? Should the connectors be connected to anything? Are they LR surplus? Previous owner have some mighty lighting rig etc? Any ideas?
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1027919 13th Mar 2024 3:09pm
TexasRover
The standard loom contains connectors for buttons etc that are maybe not fitted on your car, like adjustable headlights, alarm, speakers, etc.
I find the easiest way to identify a connector is to look at the wire colours and find it back at https://www.lrworkshop.com/
Post #1027920 13th Mar 2024 3:14pm
Martin
Site Admin
Most of them are Wabco ABS system connectors.
Looks like you have an ABS equipped bulkhead loom but no ABS fitted?
You'll have 3 unused connectors under the RH seat as well, near the fuse box under there.
The black with 2 wires would be the condensor fan connector I believe, wire colours should be BLACK and BLACK/BROWN. I assume you don't have air con (although from photos you have an AC nose)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027921 13th Mar 2024 3:18pm
Looks like there maybe some surplus antenna cable there too, the figure of eight bound with tape part. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1027927 13th Mar 2024 3:44pm
