Home > Wheels & Tyres (L663) > TPMS sensors |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
The TPMS sensor is part of the valve but it's the part that is inside the wheel so it's difficult to tell from the outside whether you have them fitted or not. At one time the valve stems being metal would indicate that they had tpms valves fitted but now you can get sensors with black rubber stems also You can take the dust cap off and there may be TPMS marked on the brass section if not the only way to be sure would be to either break the bead on the tyre and have a look or fit one of the wheels, take the car for a short drive and see if it picks the sensor up. The sensors can be changed between wheels Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
13th Feb 2024 3:05pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 656 |
I assume you’ve bought a take off set, in which case they should come with the sensors as you’d have to remove tyre, remove TPMS valve and fit a non tpms valve to remove them. Very unlikely by most people swapping them for larger alloys.
Easy to spot in person if they’re still there. When you fit them, just reset TPMS and after a few miles they’ll appear. |
13th Feb 2024 3:06pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 849 |
If the TPMS throws up an amber light on the dash, it's an MOT failure.
13th Feb 2024 4:36pm |
