Home > Wheels & Tyres (L663) > Non-stock tires |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
These on the 18” steel wheels is what I’m going for |
13th Nov 2020 4:36pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
Fab pics! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
15th Nov 2020 12:17am |
rutiger Member Since: 30 Dec 2020 Location: wa Posts: 32 |
275/55/20 ridge grappler installed this morning. no spacers or lift.
Click image to enlarge |
4th Jan 2021 9:36pm |
Babadook Member Since: 01 Feb 2021 Location: Lugano Posts: 3 |
Hello,
Someone tried this measure 305 / 50 / 20? The sidewall is the same of 275/55/20 but is more width. |
8th Apr 2021 8:30am |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
on the standard tyre there is around 20mm gap between tyre ans suspension on the front.
So would be close or touching.. (305 - 255 = 50 / 2 = 25mm extra width behind rim) |
8th Apr 2021 12:40pm |
Mikemillar89 Member Since: 30 May 2013 Location: Cheshire Posts: 17 |
Did 275 60 20 fit on a standard car no lift etc Thanks Mike |
12th Jan 2024 1:24pm |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 35 |
I fitted these to my 18” compomotives,
265/70/18 radar renegade rt+. Used them for a couple of days laning in the Lake District, all good, little bit taller than standard but no rubbing. Slightly louder. D300 Click image to enlarge Click image to enlarge Click image to enlarge |
12th Jan 2024 7:16pm |
Very similar size to te 265 60 20. What did you do with the rear brakes?
12th Jan 2024 7:36pm |
Swapped caliper carrier for the early D5 version. Uses same discs and pads but has a smaller carrier. Same as lucky 8 but without the £1000 premium
12th Jan 2024 11:50pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 784 |
Similar to what we had done to our P400 in Oz, Tuff Ant do a full ADR (govt regulator) approved LR OEM D5 rear caliper swap for D300/P400’s so you can switch to Tuff Ant 18” alloys. Not cheap but allowed me to swap to 275/65 R18 Falken Wildpeak AT3W which are LT construction Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
20th Jan 2024 6:56am |
That’s what gave me the idea, after much reading up and checking of disc sizes, I took the gamble of purchasing a pair of carriers from the D5 which had the same discs and pad part numbers as my Defender, relatively cheap at £140 a side, already had the wheels
20th Jan 2024 8:21am |
