Home > Tdi > Injector leak? |
MJN100910
Pipe-spill return fuel injection ERR1304 Washer-sealing, Engine Code 11L 2.5 TDi Diesel Turbo Manual QTY8 300Tdi fuel return pipes do split and leak and banjo copper washer too if High presser metal fuel pipe make shore they nipped up 1/4 turn but do not overtighten banjo bolts Click image to enlarge (Red ) but do not overtighten banjo bolts (Orange ) High presser metal fuel pipe Last edited by dorsetsmith on 30th Dec 2020 7:39pm. Edited 6 times in total |
30th Dec 2020 6:03pm |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
Thanks Dorset.
Is it 4 of the washers? One per cylinder? |
30th Dec 2020 6:08pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
Eight of the washers, they’re banjo bolts so one each side of the fitting for each injector. The hose looks perished so it might be the source of the leak also.
Don’t overtighten the leak-off banjo bolts - they snap very easily. |
30th Dec 2020 6:14pm |
Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 41 |
If the braided/rubber pipes are perished the engine should start better (after sitting/overnight etc) with new ones.
30th Dec 2020 7:46pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 301 |
I changed my braided pipes with some I got from Halfords for about £5. Takes about 3 minutes and the old ones were very brittle.
30th Dec 2020 10:56pm |
Bits and bobs ordered, just at the mercy of Bearmach and their Christmas hours.
Can’t for love nor money find banjo bolts, sold out everywhere seemingly. I’ll just have to be careful. Case of nipping them up then a 1/4 turn? |
30th Dec 2020 11:07pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
Run the bolts down to stop and then maybe 10°.
Mo The Land Rover 90 - Many are called, few are chosen. |
31st Dec 2020 12:08am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 603 |
In twenty plus years of 300tdi ownership The only leak off hose I have found that actually lasts is St Gobain Tygon hose. Expensive but worth it.
Every braided hose I have tried has lasted 6 -9 months before breaking down. |
31st Dec 2020 6:53am |
Fixed today. Only one snapped banjo on cyl 4.
Overtightened it going back on and snapped it. Luckily had the old ones so no issues. |
7th Jan 2021 10:14pm |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 204 |
Does anyone know the internal and external diameter of the flexible braided hose needed for the fuel return hose?
21st Nov 2023 2:10pm |
