![]() | Home > Maintenance & Modifications > Water in through A pillar |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Yes a very good dollop of silicon will do the job get a good one tho you get what you pay for
the cheep silicon is ![]() ![]() |
You could put an o ring between the snorckle mount and the a post,don't over tighten though. 2.4 90 XS
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
Use good quality clear silicone - Dow corning 785 is the best.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Strange
ive fitted 3 snorkels - not a new one or one on a new 90 and ive not put any sealant on 2 of them. the 3rd i did and waxoyl but ive not even heard of this, so the question: a) was the install correct? b) are you sure its coming in there? Mike |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Thanks for the tips guys.
mse - I'm certain it's coming in there. We've had footwell leaks before from the bulkhead that dripped small puddles on the mats, but this was different. A totally different amount of water on the mat. I lifted it out and poured the water onto the tarmac. What leads me to my diagnosis is: 1. The plastic duct that holds wires on the inside of the driver's side A-pillar had a whopping drip hanging off the end of it (i'm certain it winked at me); 2. There was a splash on the end of the dash where the water would have dripped down from the duct i mentioned above and onto the mat; 3. I don't trust my dealers not to have drilled a hole too big for the job, for example.It's the kind of job i can imagine they'd give to the apprentice or new boy. It's booked in Saturday week for it to be sorted between 9 - 1. I had an apology within 1 minute of calling - rare as hens' teeth! Will keep you posted... |
i can believe a dealer mistake...but whats the extent of the damage?! Mike
I agree no massive damage per se, but it's still unacceptable for errors like this to happen in my book. British Leyland, i know
![]() There was probably half a cup of water on the floor. More damage to my patience really and to the fact that i'll have to waste time next saturday. |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Hi 110seb
When i fitted my rai i put a piece of rubber between the screen and the bracket so it would compress and make it water tight. Also, i thought it would do less dammage to the screen if i bashed the rai on something. 130 crew cab 98 V8 Disco |
Good thinking. I'm going to suggest this to the mechanics. In my mind's eye they all walk around the workshop with crossed eyes, groaning from the effects of their lobotomies. |
I thought there was a rubber gasket - safari has one Mike
The LR mechanic probably used it to pick out a piece of his breakfast stuck between his teeth and then threw it away.
They couldn't organise a proverbial in a brewery, that lot! Hey-ho. |
i can feel your love of that dealer ![]() |
The Mantec one didnt come with any gasket. 130 crew cab
98 V8 Disco |
