Home > Puma (Tdci) > Diff lock dissengaged in rough roads |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
Come on be fair, that's more than just a broken driveshaft Anyway the difference between being stranded and getting home can in some cases be life or death. I wouldn't recommend driving front wheel drive only if you can help it, as like you have experienced, the front diffs have been known to explode from the ordeal. But in the right situation it is an option. Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
5th Mar 2009 10:16pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
A broken half shaft caused that
6th Mar 2009 12:17am |
How?
Did you break a half shaft and then drive for hours like with all the drive force going through the front diff? Please tell us the full story. Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
9th Mar 2009 1:53am |
mhasting2004 Member Since: 07 Dec 2008 Location: Gosford Posts: 29 |
Well I went out and had a bit more of a play and here's what I think.
First off the bent link was just a tad too long so that the selection lever on the T/C was just shy of the detent position. I stuck it in the vice and gave it a few belts with a hammer to shorten the distance between the bends. Second I drilled a couple of holes in the ends and replaced those horrible push on retainers with split pins. Honestly those push on retainers are for toys and have no place on my fender. This fixed the detent issue but the feeling is still a bit vague and the amount of throw of the diff lock lever is still far too short for my liking. The next fix will be to change the pivot point to a point maybe 2" lower so that the full throw of the lever in the cabin is used. This is going to take a bit of time so its on the "to do list". LR should really fix this but I won't hold my breath. Cheers MArk |
14th Jul 2009 1:00pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
mhasting2004,
Mine has been solved by the dealers. Was a lever adjustment problem. Until now, we have didnt saw the problem again. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
14th Jul 2009 2:42pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7876 |
one of the first things on my mind is engaging diff lock as soon as i come off a good firm surface, ie anything that would allow a tyre to loose traction, that may be a gravel track on worn road tyres (where as for an MT i would leave it in open diff) or a wet grassy field on ATs or deep mud for MTs etc etc for gravel tracks in Africa i would (and have) use(d) diff lock at most speeds. if the track is too firm you will get wind up but this will invariably be lost as soon as you hit the next powder section or if it gets too much will release its self through the tyres by making them slide(?) on the gravel, bear in mind you can make tyres chirp on tarmac through windup. yes if there is a big build up you will increase the chance of roll over but thats alot of wind up and you would feel it through the steering before that. my Puma also jumps out of difflock, normally on bumpy hill climbs - its on the list for the dealer to sort! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
23rd Jul 2009 9:44am |
