Home > Puma (Tdci) > rear seat folding mechanism stuck
rossy
before I traipse up to the dealer 60 miles away I thought I'd just ask !
As all you SW owners know in order to fold the rear seats you push down the lever by the seat squab, fold the seatback over and then pull the handle at the back, finally tumbling the whole thing over.
The problem is putting it back again ! I tumble the whole thing back but when it comes to raising the seatback it doesn't click back until I have manually pushed up/wrested with/sworn at the seat squab lever. Wouldn't normally be such a big deal but if little fingers push it down while the vehicle is moving then its not going to engage all by itself again.
The problem one is the larger of the split/fold seats.( The small one's like a Swiss watch, well not quite perhaps Laughing ) I have sprayed all manner of stuff in there, Lithium spray, GT7 etc and its still stiff. This seat also jiggles about more than I would expect it to as well but all mountings are tight
Anyone else come across this problem ?
Post #105813 9th Dec 2011 5:45pm
richuk
yep, mines much the same! Will be on my list for the dealer to sort out next service. Rich
semper in excretia sumus solim profundum variat
Post #105826 9th Dec 2011 6:30pm
Zagato
Check the floor folding brackets back are up properly first then slam the seat base back down hard it should then allow the seatback to go up Thumbs Up A good slam all ways works for mine, Defender fine engineering Laughing
Post #105827 9th Dec 2011 6:39pm
DAZ110
......yes a good slam down works on my seats. Thumbs Up
Post #105880 9th Dec 2011 9:15pm
rossy
thanks guys I tried brute force and its slightly better in the sense that the lever clicked back eventually (which it didn't before) but you have to shake the seatback violently. Doesnt say that in the handbook Whistle
Post #105919 9th Dec 2011 11:37pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Hahaha I thought I was the only one with the SLAM technique.......I'm not alone!! Rolling with laughter
Post #105957 10th Dec 2011 10:01am
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
Rossy,
I fitted up a draw system to my Puma. I had all seats folded forward while I worked. After finishing the installation I went to fold the seats back and the seat would not relock on the catch on the floor and the seat back would not fold back to the upright position
I then mucked around with mountings and things and could not find the problem. I removed the seats and put them back as I had removed the catch on the floor during the instalation and put it back. No good - seats still would not lock. I removed some of the draw system and blow me down the seat locked perfectly. Put the draw panel back and the seat would not lock again even though the draw was not touching the seat back.
By accident as I was stuffing around trying to fix the problem, I moved the pull release loop of the seat and all of a sudden the seat back could be moved back into the lock position. What I discovered was that the loop would just catch on the rear of the draw set which stopped it going fully home. It was only a matter of milimetres but was enough to stop the whole seat mechanism working properly. pushing the loop fully home fixed the problem.
If the seat back will not go to the upright position push the locking/unlocking loop fully home and this might fix the problem. In this case just a gentle push to make sure the loop was fully home solved my problem. Obviously I can't say if this is a similar problem to yours or others, but check just the same.
Good luck.
Post #105958 10th Dec 2011 10:06am
Happyoldgit
I had this on one of mine, mentioned it to the dealer who said it was fixed but it started playing up again soon after. I ended up removing the plastic trim and lubricating the whole mechanism, while doing this I found that the Allen head screw which hold the catch onto the shaft was loose - tightening this up made it better. That said I occasionally still have to manually push the loop handle down to engage the lock as sometimes it still doesn't want to engage by itself. Steve.
http://forums.lr4x4.com
Post #106024 10th Dec 2011 6:41pm
rossy
thanks MOG and 4wheeler
yep when I covered the bare patch of metal near the loop handle I realised that it had to be pushed in the last few mil before the seat would go back. The problem I have now is that the seatback when up doesn't lock in the upright position unless you physically move the little lever by the seat base up (it should pop up and lock automatically). Well it kind of does now since I started to apply violence but I think I'll dismantle part of it and look for a fault in the mechanism before trying the dealer or battering it further !
Post #106060 10th Dec 2011 10:17pm
richuk
This is exactly the same on mine. The seat back is also considerably stiffer to raise back up than the single seat. Please let me know if you have any luck fixing it. Rich
Post #106193 11th Dec 2011 5:33pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Anyone had a "fixit" for this problem, as my seat (left hand side) will not disengage the lock and will not fold up.
Thanks in advance. Cogito ergo sum
Post #365849 20th Oct 2014 11:28am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Push the fabric strap (that you use to release the base) fully back down Very Happy
Mark.
Post #365900 20th Oct 2014 3:44pm
mk1collector
^^^ this Thumbs Up
Post #365903 20th Oct 2014 4:17pm
ericvv
Mark.
That is correct. I had the same issue after the SVX turned 5 years old, and tried to get the mechanism renewed under my extended warranty. Which did not work for this case. The price of a new mechanism is mouth watering, so my dealer showed me as Mark says, to push the strap manually completely down, and then the seatback will fold up completely and properly lock. I can live with this solution for the rear seats. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #365917 20th Oct 2014 5:04pm
Paul55
Thanks for the quick replies guys, have sort of fixed the problem but only short term, took off the side cover and the small wire was loose had to pull it with some long nosed pliers to disengage the lock, worked fine but still unsure what a long term fix is, any ideas anyone ?
ps, Martin uploading the photo was spot on, nice and easy Thumbs Up Cogito ergo sum
Post #366116 21st Oct 2014 10:45am
