Home > Puma (Tdci) > Defender Puma 90 stepped rear wheel boxes
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
For those of of you who may have removed one or both of the factory fit front facing seats from your Puma 90’s I have a question.
If you wanted to fit a storage box to one side internally how would you go about levelling up the step so that it was flat like those found in the hardtop version?
I would be interested to hear any suggestions or from those who have found a solution.
Jim
Post #1065146 9th Apr 2025 7:01pm
DSC-off
I used aluminium box section from B&Q to fit a shelf. 2 lengths stacked to make up the 40mm step height. Each 35 x 20mm.
Bolted them down using the original seat fixing nuts under the arch. Details here,
https://www.defender2.net/forum/topic54147.html
Post #1065371 13th Apr 2025 5:35am
