Home > Puma (Tdci) > 2009 110 USW - Wet carpets
Page 2 of 2 <12
ZeDefender
Just a thought: won't a nice thick coat of waxoyl etc. block off many of the ingress points underneath, e.g. floorpans? Tell someone you love them today because life is short.
Post #108827 20th Dec 2011 9:15pm
roadracingtog
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Strangely there hasn't been a repeat of water spray from the wheels getting into the load space? It is waxoyled already. I'm keeping an eye on things for now. I've ordered some RTV silicone sealant and I'll investigate some more but an old t shirt on top of the wheel box seems to be doing it's job Laughing Laughing Laughing
Post #108855 20th Dec 2011 10:57pm
ZeDefender
Just remembered Idea the first time I went out in rain in the 110, the nice new carpets got wet all down the slope behind the third row seats and on the floor.
Turned out water was getting in around the plates that fix the body to the support strut. It's exactly where all the spray shoots up above the rear wheel arch. The plates were a bit loose and LR don't seal around there at all!
All I did was take the plates off, fit big rubber washers (bicycle tyre) around the studs and do the plates up nice and tight. No problems since Thumbs Up Tell someone you love them today because life is short.
Post #108874 21st Dec 2011 7:39am
roadracingtog
Thumbs Up
Post #109233 22nd Dec 2011 7:18pm
roadracingtog
Dry as a bone! For now at least Laughing
My 110 returned from Hunters with all the holes and leaks now sorted. Chatting to the technician in the body shop the major point of entry was the door seals! I hadn't spotted any problem. The water was running down the seal, concealed, until it appeared beneath the carpets and fooled me into thinking there it was getting in between the floor and the rear seat box Rolling Eyes
The other thing that he mentioned was the alignment of the roof/side panels and tub. A slight misalignment was allowing water to weep past the seal between the tub and side panel. Because I park on a slight incline the water would pool around the area of the speaker trim in the rear load space. A tightening down to level off the side panel cured the problem.
I can't fault Hunters of Chester for their service though and I did get to try out a brand new Freelander for a few days too.
Post #114720 12th Jan 2012 7:28pm
ZeDefender
Hard work pays off - congrats Thumbs Up Tell someone you love them today because life is short.
Post #114730 12th Jan 2012 7:44pm
Page 2 of 2 <12
