Home > Puma (Tdci) > Steering box adjuster nut
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Hi all. I’ve got a leak from a fairly new steering box. Likely cause I think is the locking nut with built in seal - RTC4394. Nut plus VAT and postage seems to land around £25 which is nuts for a nut!
Can’t I just use an o ring, washer or use marine sealant etc? 2010 2.4 TDCI Puma Defender 90
Post #1064342 31st Mar 2025 8:54pm
Dinnu
Slacken the nut by a turn / 1 millimeter, and wind a few turns of ptfe (thread) tape. That should seal it.
If the box is adjusted well, keep an allen key on the adjuster so you do not loose the setting. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064363 1st Apr 2025 4:56am
SilverPuma
Thumbs Up 2010 2.4 TDCI Puma Defender 90
Post #1064461 1st Apr 2025 7:44pm
