Home > General & Technical (L663) > My half day LR experience at Butterstone
Eric Caterpillar
Went to Dunkeld last Friday to do my new owner experience drive.
Arrived at 9 am to see a row of Pangaea green Defenders 110 and already had a big smile on my face. My own Defender is almost exactly the same spec, bar rear diff, black interior and Goodyear Wranglers.
Haven't really had a chance to take any more photos as I was alone, without my second driver.
It was really good to see these cars put to the test in their intended environment.
To summarise my experience, the car was more capable than I were, but that's why I'll come back to do the second half day upgrade and take it to some more challenging spots.
The main thing for me was to be able to learn how to work with the car taking into account it's size and manoeuvrability and to see how different drive modes work in real life
Pretty much didn't use the Auto mode as my instructor said it's behaving retrospectively, rather used GGS, M&R, RC or Wading from the outset.
Did try the off road cruise control, however, as much as it's entertaining, it takes away from doing the drive yourself.
Did deliberately bottom out to see the additional lift on the air suspension, would be great for washing the underbody.
The Defenders available on the day we're a mixture of 90s and 110s, mine was a D350. Asked if I could do the trail in a Disco or RR, but only Defenders were suitable to that trail due to their off-road clearance. As I said, the car is so capable, haven't even scratched its limits, but it made me even more happy that I bought something a bit special.
Thanks for reading. Cheers!
Post #1063884 25th Mar 2025 7:08pm
falkster
Germany 1988 Defender 110 V8 Petrol CSW Trident Green
They are fantastically capable cars.
Due to my job I had the chance to drive the pre-production prototypes and more recently some regular ones on team day out's.
As much as I love my '88 OneTen V8, I would prefer the new one as a daily drive for sure.
Off-Road though, this is where the old Defenders are much more engaging as there are no computers to do the work for you.
But anyway, the new ones are still impressive to move around and see what tech can do nowadays.
Glad you enjoyed the experience. Thumbs Up  1988 Land Rover OneTen County SW, 3.9l Petrol V8 (serpentine), original "Santana" LT85 gearbox
Post #1063894 25th Mar 2025 8:20pm
Chicken Drumstick
Re: My half day LR experience at Butterstone
Glad you enjoyed it, but do bear in mind that the course is a "demonstration" course. It isn't designed to get you stuck or really push the vehicles all that much. Out in the wilds you can certainly find the limits of any 4x4 much easier.
Biggest thing to learn with modern LR's is which Terrain mode to use for the ground conditions. Specifically on if you need or want wheel spin, some modes will kill the throttle and get you stuck. Even if the mode would appear to be the correct one if you go by the simple descriptions of mud, grass, snow etc.
You can also use the terrain modes to smooth out the throttle, e.g. the snow mode works really well if you are driving over a ploughed field, as it'll make the throttle pedal a lot less sensitive.
Post #1063900 25th Mar 2025 9:17pm
Moo
Ukraine
Glad you enjoyed it. I let my daughters do the experience. Best take aways, other than its capability, were using the rear wash to clean the camera and how to switch off ACC. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1063910 25th Mar 2025 11:02pm
XplusYplusZ
Love the Dunkeld facility and Team. Particularly the actual trails, not just the obstacle course - although their BIG hill is obscenely steep!
I have definitely used lots of the advice I've learnt:
You can use GGS for some improved control in any slippy condition - even on cold/wet tarmac
As you pass an object, when it's in line with the wing mirror from driver's perspective, at about an arm's length from the vehicle, you can turn full lock and not hit the object. (Useful in forests, and waitrose carparks alike).
The bottoming out to raise suspension is a pretty impressive trick - especially useful for slightly overconfident wading and having to vehicle tip-toe out..
Obviously, Hill descent is great to learn to use properly
Rock Crawl guiding was also useful to learn a little about - aiming to put your wheels ON the big rocks, rather than trying to figure out if you can straddle them was not intuitive for an amateur like me.
Also, just getting a feel for just how steep an obstacle must be to flummox this vehicle was shockingly impressive.
Anyone else come away with really useful day-to-day stuff?
I'm feeling the need for another trip up north!
Post #1064030 27th Mar 2025 2:12pm
