![]() | Home > In Car Electronics > Wired winch remote wiring |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17715 ![]() ![]() ![]() |
It is pretty well guaranteed to be possible, however it would be useful to have some wiring info about the solenoid.
Is this the same one you were asking about in 2022? Most likely something like this will work, this is for an Allbright solenoid. I haven't yet met a 5-wire control that cannot be wired as a 3-wire control. ![]() |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 228 ![]() ![]() ![]() |
Thanks blackwolf and that's correct it is the same one.
So looks like the third wire from the controller needs a fused positive feed back to the battery going off your diagram. |
