Home > Technical > TD5 dowty rings & gaskets
Tandy
United States
Does anyone know the part number for the 2 dowty rings that go over the banjo bolts inside the oil cooler.
Also the 2 green rubber gaskets that go into the heat exchanger core.
1999 TD5 10P engine
Post #1062738 12th Mar 2025 9:19pm
Tandy
United States
Here's a picture of my oil cooler casing. The red arrow points to ERR7098 oil cooler o-ring, but that's not what I need.
I need the 2 dowty washers for the banjos and 2 o-rings for the heat exchanger.
Thanks!
Post #1062741 12th Mar 2025 9:41pm
Tandy
United States
I think I've possibly found some part numbers, but they only correspond to a seller in Australia.
BS120 .....which appears to be the Viton o-ring
BD233 .....which appears to be a dowty washer
Still looking for an easier way to source these, and perhaps an actual LR part number.
Post #1062745 12th Mar 2025 10:03pm
Tandy
United States
OK I found what I was looking for.
The heat exchanger inside the oil cooling casing of a TD5 uses two gaskets, (BS120) 2.62mm x 25.07mm Viton / FKM o-rings.
The banjo bolt washers are M22 dowty seals.
Both available on the internet from various fitting/gasket/hose stores.
Post #1062757 12th Mar 2025 10:39pm
