ABS pulsar ring
When I installed my LOF brakes on the rear, I had to swap over the old ABS pulsar ring to the new LOF discs.
When I went to do the front brakes, there appears to be no ABS ring on the old brake discs.
Do front brakes usually have an ABS ring? The previous owner had new front brakes installed a year before I purchased the Defender. I have the 3 amigos illuminated. Could they have neglected to install this ring back on the front or is it supposed to be this way?
1999 Defender 110 TD5 with ABS
12th Mar 2025 1:07am
landy andy
The front ABS sensor is picked up off the front CV joint, with the sensor being poked in from the top of the swivel housing, not into the back of disc
12th Mar 2025 2:34am
Tandy
