![]() | Home > Maintenance & Modifications > Defender Puma 110 Engine Swap & Automatic Transmission |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8201 ![]() ![]() ![]() |
which one then M57 or LS3?
my M57 kit came from MW Machines. will be going back there for the next one. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
seeta Member Since: 11 Mar 2025 Location: Riyadh Posts: 3 ![]() ![]() |
My main priority in deciding between the two is cost, and from what I’ve read online, the M57 seems to have a better price, so I’m leaning towards that.
If you don’t mind me asking, how much did it cost you in total? And did you need any other parts or modifications beyond what came in the kit? |
Prices on his website, just go through and pick and choose the bits you want.
Hoses are all straight fwd. Fuel ines straight fwd. Only really ecu, waiting, control boxes and mounts plus exhaust options. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks, James! I really appreciate your help. I’ll check the website and go through the options.
By the way, did you go with an automatic gearbox for your M57 swap? If so, which one did you use, and do you have any advice on the conversion? |
One has an mt82 on the back of a 184
The other 6hp28 on back of 232. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
