Home > Puma (Tdci) > Rear Half Shafts Changed. . .
Andy344590
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Indus Silver
I have beein having a drive clunk when changing gear etc since buying the 2014 2.2 D90 CSW last year, and it sounded like it was coming from the rear end.
So after searching the forum for info, and reading quite a few posts about the same problem Bow down , I decided to go the easy option first, replace the half shafts and with the one piece LOF shafts as recommended by BrickBox. https://lofclutches.com/shop/misc/defender...ve-shafts/
Quite an eye opener when I removed the drive cover on the off-side shaft . . . now i know why I had a clunck, and the other side was not much better either.
Replaced both half shaft and a quick test drive, and now all good Thumbs Up
Post #1062201 6th Mar 2025 5:20pm
You can see the wear and the metal dust around it can’t you, mine was like that before I changed them, only in my case I went Ashcroft 2 piece and they’ve been great.
You might want to consider the Ashcroft HD flanges on the front?
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1062202 6th Mar 2025 5:30pm
BrickBox
Thumbs Up Glad it’s sorted for you. 2008 2.4 110 Utility Station Wagon XS.
Post #1062204 6th Mar 2025 5:42pm
TexasRover
Given the condition, I would replace the bearings. Looks pretty dry and that metal/rust if it has reached the races will have affected the surface, causing the hardening to fail dragging the whole bearing down with it.
Post #1062205 6th Mar 2025 5:42pm
Andy344590
Thumbs Up
Just checked out the Ashcroft front HD Flanges, looks like the bank balance is going to suffer again Whistle
Post #1062265 7th Mar 2025 10:12am
Andy344590
Good point, I will keep an eye out for this, it looked like the bearing had an in-built seal when i cleaned up the mess however looking at the LR drawings, it looks to be a taper bearing from the part number https://parts.jaguarlandroverclassic.com/p...and-rover/
Anyone had this problem with bearings?, advice needed from Forum Bow down
Post #1062268 7th Mar 2025 10:19am
andy63
I did the same job a while back.. my half shaft splines looked a bit like the photo above in terms of they were dry and reddish , but in reality not that bad.. i put the lof one piece ones in anyway and unlike you didn't really notice a great deal of difference..
I think most of my clunk will be in the diff, and I've never really had a close look at the A frame ball joint..
Post #1062269 7th Mar 2025 10:26am
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
Yes, they are tapered roller bearings and no there is no built in seal.
I would replace those bearings for peace of mind. Or at minimum take everything apart, clean thoroughly and grease.
Post #1062272 7th Mar 2025 11:14am
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Same here!, I switched to 1 piece last year. made quite a difference.
I also had wear in the Output Shaft so replace that 2 when I was get the clutch done. Its like a different car now 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1062283 7th Mar 2025 1:31pm
Andy344590
Looked through online Haynes Manual I bought last week, 210Nm torque and 52mm socket, holy moly. Shocked
Haynes manual says to check end float and adjust with spacer, take it the end float should be already set if not replacing the bearings
Probably clean and inspect the bearing first.
Post #1062305 7th Mar 2025 6:18pm
TexasRover
Oh dear you are opening up a can of worms now: the single nut v double nut discussion(look it up). What you have is the later single nut fixed spacer solution. It's best to have the right socket before you start. The torque value is not that important so don't worry too much about that. Unstake the nut before loosening it then just remove and reassemble with same spacer, new bearings or not. Ideally you fit a new nut, but you can restake the old one. Just tighten it up tight.
Now you need to remove your caliper to remove the hub and you need the right socket for that 12 point 13mm (or maybe 15mm) but don't use a six sided as as you could round the heads. Hammer the socket all the way down on the head. They are typically tight so a long lever makes this easy. Locktite is used on refitting, or get new boots which have the compound on it.
Post #1062323 7th Mar 2025 9:07pm
Johan_B
As long as you keep the same hub you can keep the spacer that is in there. With 210 Nm the spacer will compress slightly and provide the correct end float. The bigger problem may be to undo them…
As said, calliper bolts are 13mm 12-point, get new ones.
Why not measure the disc as well while you are there, minimum running thickness is 12,3 mm I believe. It doesn’t add a lot of work and then you know you’re good to go for many years. Disc also has a 12-point bolt, think it’s 14mm could be 15.
Post #1062346 8th Mar 2025 7:57am
Andy344590
All the posts I have read mention how tight it is, has anyone used an Impact Gun to remove the hub nut?, I have a one that is pretty powerfull, like 800Nm of removal torque.
Johan_B / TexasRover thanks for the advice on spacers and caliper removal sockets, and i willl check the disc, however the caliper is not in the best condition either and the pad jewellery is pretty rusted.
Just checked my torque wrench and its good for 300Nm, so half way there now. I have found a 52mm impact socket on quite a few LR parts sites, so will order one.
One relativley quick job is turning into a whole lot of other work . . . sounds similar to others Laughing
Post #1062355 8th Mar 2025 10:19am
Andy344590
TexasRanger . . . Just searched the single nut v double nut discussion . . . . hmmm see what you mean Whistle
Post #1062357 8th Mar 2025 10:32am
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
You just need a long breaker bar or a steel tube to exstend, so you can apply a lot of torque. It is not something to worry about as long as you have some sturdy equipment with appropriate proportions. Just make sure you unstake the nut in order to preserve the threads.
Post #1062359 8th Mar 2025 11:12am
