![]() | Home > Puma (Tdci) > A/C fan looks wrong? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
That's correct. It is an aftermarket condenser with the original fan fitted.
The aftermarket condenser is bigger/designed for hotter climates. I have the same condenser fitted and opted for a bigger fan that fits to the tabs provided as shown below ![]() Click image to enlarge > 110 XS Double Cab |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 922 ![]() ![]() ![]() |
Thanks Hank
![]() Not used to Defenders having A/C… Jim |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 200 ![]() ![]() ![]() |
That is not an original fan. It is way, way undersized. Land Rover AC fans are powerful and draw serious current. Most off-the-shelf rad fans are not up to the job.
PS: Whoever installed it should be shot without a chance to make peace with their maker. Steel bolts through an aluminium heat exchanger?! |
JB, my thoughts exactly!
However the A/C blows ice cold. Jim |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
It does look like the original fan to me, less a chunk of the mesh/grille. Landrover also mounted the fan with steel bolts through the condenser!
Missing bumper bolts because the condenser takes more space? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 224 ![]() ![]() ![]() |
Here's a shot of mine, original condenser and fan (2013) bolted straight through the condenser.
![]() ![]() Click image to enlarge According to the JLR parts diagrams that looks as though it was designed like that and they hadn't just run out of brackets at Solihull on those days. ![]() Click image to enlarge |
I'm still "agin" it! (wink)
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 522 ![]() ![]() ![]() |
Hank did yours come black or did you spray it black |
It came black
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
this is how it's supposed to look like
![]() (original MY 2015) ![]() Click image to enlarge |
cechurap Member Since: 22 Aug 2020 Location: Prague Posts: 13 ![]() ![]() ![]() |
Hello Hank, please could you be so kind and have a look for the part nr. of the bigger SPAL fan? I have bought the same aftermarket condenser - NRF 350489 and I am not sure, which fan will fit there.. Many thanks. Petr |
I'm about to fit the same condenser:
![]() Click image to enlarge This fan bolts right in: 14 Inch 1,841 CFM Spal Electric Fan IX-30102056 https://www.summitracing.com/parts/SPU-IX-30102056 |
Great! Thank you very much
This set up still doesn't look right to me.. It looks as if the frame for the original Land Rover condenser has been used to mount the replacement aftermarket one? Should the old frame not have been removed? Jim |
