Home > Technical > 2.2 Puma TDCI odometer light
Bradders130
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Indus Silver
So I’m hoping that this will be an easy one to answer.
I had a few issues with the drivers electric window not working on my 2.2 puma only to find out that, with all that I’ve been doing lately, the fuse responsible had found it’s way into a vacant space… duh.
Anyway, whilst I was diagnosing the problem, I saw that when I turned on the ignition, the odometer illuminated. Now I don't remember seeing this lit up before, except after I’ve turned the lights on and the whole dashboard is lit up, including the odometer.
So is someone able to confirm, one way or the other for me please if the odometer lights up, with just the ignition on and the lights off?
Post #1061904 3rd Mar 2025 10:25pm
Dinnu
My odometer lights up with ignition, and dims when the lights are switched on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1061930 4th Mar 2025 2:36am
andy63
Mine also lights when you turn the ignition on, but a lad showed me you can turn it on by pressing the reset button when the ignition is off..
Handy if you just want the info and you don't have the key, or just saves cycling the ignition to see it..👍
Post #1061941 4th Mar 2025 8:02am
Bradders130
Thanks Dinnu and andy63. That puts my mind at ease.
The weird thing is, is that I’ve owned, “Stumpy” for just over three years and can’t remember whether its illuminated or not….. despite being in the car for hundreds of hours and probably looking at it nearly every day!! Rolling Eyes
Post #1061954 4th Mar 2025 9:51am
andy63
Sounds just like me as well🫣🤣👍
Post #1061956 4th Mar 2025 9:59am
