![]() | Home > In Car Electronics > Rear Worklamp wiring |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1105 ![]() ![]() ![]() |
![]() Bit hard to see the way you've drawn it, but you're using a "staircase circuit" here to be able to switch the lamp on/off from two locations https://www.sparkyfacts.co.uk/_media/two-way-lighting-circuit.png |
BobC Member Since: 31 Aug 2023 Location: Cumbria Posts: 10 ![]() ![]() ![]() |
Yes, that's exactly what you use for two way switching. The additional element is integrating that with a 3 way switch to select operation with reverse gear, all off, or two way switching feed from leisure battery.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1156 ![]() ![]() ![]() |
the next advancement of the 'staircase circuit' aka 'hotel circuit' is to use a simple Electromagnetic Pulse Relay (https://www.amazon.co.uk/plikc-Electromechanical-Pulse-Relay/dp/B08DKK5S16) which can be purchased cheaply on various voltages (12/24/110/230v) and AC/DC.
This is a very simple mechanical device that basically uses a electrical pulse and electromagnet to advance a cam that switches on and off a set of points. pulse on - pulse off etc. You can buy them in fancy electronic versions with timers etc too, but you have to watch the voltage etc. ![]() The benefit is that you can create this pulse from any low current daisy chained NO push switch ('doorbell switch') or cheap remote receivers. Also it does not use power other than the pulse and is unaffected by power outages etc (e.i on remains on, off remains off). However it does not work with permanent contacts like the reverse light switch in the gearbox, but you could bypass (override) it for the reverse light application. The above is just sharing of some knowledge for those that interested in this kinda stuff as DIY projects. |
