![]() | Home > Technical > 2.0 MPI engine stuttering at certain throttle position |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4254 ![]() ![]() ![]() |
My first thought would be ignition. I don't know what ignition system these engines have, but probably worth checking that first. 2007 110 TDCi Station Wagon XS
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 863 ![]() ![]() |
Does it feel like a fuel or electrical misfire?
Basic service items, plugs, leads, coil etc. Check these first. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2232 ![]() ![]() |
I believe the engine is a Rover 2.0L T16 DOHC petrol engine. https://en.m.wikipedia.org/wiki/Rover_T-series_engine
Good engine back in the day. My Dad had a Rover 420GSI with one in and it absolutely flew. 2007 110 TDCi Station Wagon XS
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1333 ![]() ![]() ![]() |
Interesting. I think that is the same engine that was offered in the UK Discovery 1's as well.
Is it a fly by wire type throttle control on the accelerator pedal, or a good old fashioned mechanica/cable linkage to the engine? If fly by wire, I'm just wondering if the sensor on the accelerator pedal is playing up at a certain position. Something in the back of my head is saying that later Disco 2's suffered from erratic throttle control due to failing pedal sensors. (And not sure if that was on the TD5 or the V ![]() I could be barking up totally the wrong tree though. |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1392 ![]() ![]() ![]() |
Yes it is. I had an MPI Disco 1 for a while. I can't help with the running issues sorry. I needed to change my thermostat on mine. but could not find it! I called into my local main dealer to see if they knew where it was but they didn't, so got the factory workshop manual out - it was still wrapped in cellophane as it had never been used before. They were pretty rare beasts. BTW thermostat located inside the top radiator hose! Euro-Leafing to infinity and beyond..... |
