![]() | Home > Puma (Tdci) > Water Pump Oh-My-God-Rings |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 172 ![]() ![]() ![]() |
Just a quick note on water pump replacement. OEM and aftermarket pumps may come with an o-ring for the black water manifold that is more plastic than elastic. Many repeated heat cycles can result in the o-ring taking a set in its deformed state and no longer sealing. Regardless of where you source the pump, fit a genuine o-ring.
