Defender 90 Td4 Puma - Sunroof
I've recently bought a preowned def 90 TD4 Puma, with a sunroof from Britax.
Previous onwer has completely sealed with silicon the glass, so you can't open it any more.
My idea is to replace with a genuine one from Land rover, but I'm not sure the exhisting hole in the roof (yes,now I've a big hole since i removed the glass and the frame) is suitable to fit a genuine sunroof
Dimensions of the hole is about mm 790 x 430.
Only infos I have are coming from the label Ive found on the glass:
Britax / B'ham (i guess it means Birningham)
Typ 457
Art 213
KBA 9370
Genuine sunroof should be LR045412.
has anyone experience in swapping these sunroof?
once solved this issue, still remaining the problem of the saggy roof liner
16th Feb 2025 7:48pm
ickle
I can't help on sizes, but I thought the 'genuine' LR sunroof was a re branded Britax anyway?
Keith
17th Feb 2025 9:46am
Gianluca
hi. thanks for your reply. You are probably right, i was only looking for a confirmation. in the meantime i?ve found the dimensions of genuire and it looks dimensions are ok. I've ordered the genuine one today... let's wait delivery
17th Feb 2025 11:29am
TexasRover
If you zoom out a little we can see the design and arrangement. I personally thought the stand sunroof was the rotary single nob lock type. I'd be interested to see what they changed to in later years.
