Home > Maintenance & Modifications > Rust around windscreen area - Defender Puma
Page 2 of 2 <12
keith
This is my corrosion on both corners and have no idea whether to replace the screen frame or cut out and repair.
Post #1060870 18th Feb 2025 6:00pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Looks like it's not just the alloy frame, the bulkhead itself is corroding in the first pic… Confused “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1060871 18th Feb 2025 6:16pm
keith
Yes your correct the bulkhead is corroded and holed. That’s why I mentioned in an earlier post that surely a galvanised bulkhead is the only way to go to rectify the problem once and for all. The alternative is to do patchwork and painting over and over again. It’s know to be made of cheese the puma bulkhead, whereas my series and TD5 motors never had any bulkhead issues.
Post #1060873 18th Feb 2025 7:14pm
Page 2 of 2 <12
