Home > My Defender > Defender td5 help please
jamesm26@icloud.com
Hi guys need a little help . Have a 52 plate td5 on the spot she will Rev fine limiter works . When you drive it and try and bog your foot it will pull for a minute get to certain Rev and go flat nothing and smoke change gear she will pull fine again till it hits the same spot then flat again no power . Any help would be great I’ve just got new intercooler hoses arrive going to try those to. Thanks Shocked
Post #1060541 14th Feb 2025 12:20pm
ibexman
Split hose🤔
Post #1060555 14th Feb 2025 3:31pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Re: Defender td5 help please
Is the waste gate free?
Chris
Post #1060562 14th Feb 2025 4:47pm
jamesm26@icloud.com
Hi yes waste gate seems to be free and moving and I can’t see any split hoses or no noises of split hose
Post #1060563 14th Feb 2025 4:55pm
johnlad
Possibly over boosting, has anyone been adjusting the length of the wastegate arm.
Post #1060566 14th Feb 2025 5:16pm
jamesm26@icloud.com
It was doing it before I brought it so I turned it one turn to the rite still did say so then turned it 2 turns to left still the same buddy
Post #1060568 14th Feb 2025 5:28pm
johnlad
In standard tune I believe there should be 13 threads on the wastegate.
Post #1060575 14th Feb 2025 6:54pm
jamesm26@icloud.com
Ok thanks I will check it’s in garage now having service and boost pipes changed
Post #1060578 14th Feb 2025 7:05pm
Betsy
 1999 Defender 110 Td5 HT Coniston Green
Mine was doing similar but kangarooing at high revs, I swapped the injector harness, freed the watergate as was stiff, cleaned injectors. Cleaned ECU plug, but non of the above helped then
I unplugged the MAF sensor and it appears to have cured it, I’m yet to replace the sensor however so it’s still unplugged but seems to run fine
Post #1060588 14th Feb 2025 8:35pm
