Home > General & Technical (L663) > Broken p400 X
Sticks999
Broken p400 X
Hi has anyone had any problems like this.
The car stopped working on the 23 December 24. No digital display and no start button. Called LR technicians out but they had no idea. The car was towed away and I eventually got it back last Friday the 7th of February. So it took 6 weeks to fix the car and it turned out to be a blown fuse Number 53 in RJB which is behind the glove box!!!
Land Rover insisted that I had the Ghost ii disconnected before they would do any diagnostic work on the car which was at my expense. So not only did I loose the car for 6 weeks it cost me £225.00 for them to change a fuse.
Has anyone else had a similar problem with this fuse and LR warranty claims in general.
I personally think is and absolute disgrace.
This is the Engineers report
CONFIRM VEHICLE NOT RESPONDING WHEN START BUTTON IS PRESSED, FOUND REMOTE LOCKING/UNLOCKING TO BE WORKING CORRECTLY, CONNECTED VEHICLE TO TOPIX CLOUD AND FOUND MULTIPLE MODULES SHOWING OFFLINE, FOUND VEHICLE HAS GHOST FITTED SO WILL REQUIRE GHOST REMOVED BEFORE FURTHER INVESTIGATION CAN BE CARRIED OUT, ONCE GHOST REMOVED CHECKED AND FOUND MODULES STILL SHOWING OFFLINE, CARRIED OUT EXTENSIVE WIRING CHECKS AND FUSE CHECKS AT EJB, PJB & RJB AND FOUND CONNECTIONS TO MODULES CLEAN, DRY AND SECURE, FOUND FUSE 53 IN RJB BLOWN, SUPPLIED AND FITTED NEW FUSE THEN LOCKED VEHICLE WITH REMOTE THEN UNLOCKED AND OPENED DRIVER'S DOOR, PRESSED THE START BUTTON AND GETTING MESSAGE 'SMART KEY NOT FOUND' SHOWING ON DASH, CARRIED OUT NITS TEST AND FOUND NOT AS MANY MODULES OFFLINE (BCM & PCM BACK ONLINE), CARRIED OUT WORKFLOW RECOMMENDATIONS OF IMOBILISATION TEST AND RESULT SHOWED BCM BLOCKED, GOT ALL CUSTOMER'S KEYS AND USING TOPIX CLOUD RAN IMOBILISATION CALIBRATION FOR THE GATEWAY MODULE WHICH FAILED ON FIRST ATTEMPT BUT COMPLETED ON SECOND ATTEMPT, FOUND VEHICLE NOW STARTING USING START BUTTON AND ALL MODULES SHOWING AS ONLINE, CHECKED AND FOUND FUSE IN RJB HAS NOT BLOWN SINCE RENEWED, CLEARED ALL FAULT CODES THEN RELEASED THE VEHICLE BACK TO CUSTOMER,
Post #1060471 13th Feb 2025 1:03pm
