![]() | Home > General & Technical (L663) > Replacing Discs and Pads |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
I’ve done them on the last one
What dos you want to know Other than the torque the rear has a brake release for the park brake but there’s nothing special Take the wheels off both sides to turn the front for access Mike |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2725 ![]() ![]() |
Mine was pretty straightforward, basically the same as any modern floating caliper vehicle. If you don’t have a diagnostic tool you’ll need to use the fiddly sequence to wind the parking brake motors off on the rear.
You’ll need new bolts for the caliper carriers too, and replacement disc retaining screws are also a wise investment. |
Kev the Rev Member Since: 04 Jun 2023 Location: Ripon Posts: 49 ![]() ![]() ![]() |
There’s a video on PowerfulUK on YouTube where they upgrade the calipers.
Looks pretty straightforward |
Yes i didnt get the disc retaining and then quickly went to get them There is a inappropriate term for how tight the caliper bolts were on mine - my heavy duty impact worked incredibly hard to get them off with all its fancy settings Mike |
JAM911 Member Since: 13 Nov 2024 Location: Warwickshire Posts: 36 ![]() ![]() |
I have seen the Powerful UK video on how to release the parking brake.
What is the sequence to un release it? Also any torque numbers? Thanks |
Install and tighten the 2 new brake caliper bolts.
Renew Part: Front brake caliper carrier bolt(s) - M16 X 40mm Quantity: 2. Part Number: LR033274 Torque Stage 1: 133Nm Stage 2: 60 degrees Install and tighten the 2 bolts. Renew Part: Brake caliper carrier bolt(s) Quantity: 2. Torque Stage 1: 110Nm Stage 2: 120° Connect the EPB actuator electrical connector Mike |
Thank you for the info.
Can you explain what the Stage 2: 120° means please? |
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 36 ![]() ![]() |
If you don't know what it mean.... I suggest you do NOT replace Disc yourself!!!
Sorry about it... but if you do something wrong you are in truble!!! The best will happens is vibration.... |
It just means tighten more...thanks
i would tend to agree
It means a specific additional rotation to set the right tightness. - the were Fing tight Mike |
