Home > Technical > Trailer help for a Lightweight
JW911
When I bought my Lightweight, I had the option on a Sankey. Given that it was holes joined together by rust, chassis included, and would have cost a pretty penny to put right, I passed on it.
I have a normal trailer which I acquired from Gumtree, which I use a couple of times a year and has seen better days. However, a recent upgrade program at home has meant the Freelander (usual tow car) went a year or so ago in favour of a Jag F-Pace with no tow bar, so the tow car became our FFRR. That has now been replaced by another FFRR, this time without a tow bar.
A first world problem now ensues. Do I get a towbar fitted to the FFRR or do I buy a Sankey? Given my towbar options, there’s not a lot in it price wise.
Please talk to me about Sankeys/Penmans, etc. Lightweight is a 24v with a NATO hitch. Also JW911 on FullFatRR
2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #1059581 5th Feb 2025 2:27pm
Mdm
sankys are old and rusty and parts are had to find for them but they do look good behind a lr
Penamns all the way for me stainless tubs and wolf wheels and they tow great
Post #1059601 5th Feb 2025 6:24pm
A Sankey narrow-track would be the most appropriate for a light-weight and would match the track-width, a wide-track or Penman will be wider than the Land-Rover.
Post #1059603 5th Feb 2025 6:45pm
JW911
This is the hitch (fixed, I think):
2021 3.0 P400 Vogue
Post #1059620 5th Feb 2025 8:11pm
That's a standard rotating pintle so you can tow either rotating or fixed lunettes.
Post #1059622 5th Feb 2025 8:28pm
JW911
Thanks. Remember, I know just enough to be dangerous. Whistle Also JW911 on FullFatRR
2021 3.0 P400 Vogue
Post #1059629 5th Feb 2025 9:30pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Remove clip and take pin out at the bottom. The fingers will drop down allowing hitch to rotate. Put the pin back in.
Do you have somewhere undercover to store a Sankey? No matter that it has drain holes or that you can tip it up they always seem to get water pooling in part of them. They tow very well behind the Lightweight. The Penman with the tailgate is a bit more practical. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #1059664 6th Feb 2025 11:49am
JW911
Yes, I have storage. Also JW911 on FullFatRR
2021 3.0 P400 Vogue
Post #1059710 6th Feb 2025 6:58pm
sako243
I personally wouldn't bother with a Sankey / Penman as whilst okay offroad they're pretty impractical for anything else.
You've already got a normal trailer so I'd see about fitting a normal hitch to one of your vehicles. When you say FFRR is that a nice looking one (I'm biased) in the L322 or an L405? I'm not familiar with the 405 but on an L322 a few years back it was a few hundred quid for a complete setup from pfjones to fit one to my TDV8. Afternoons work removing the bumper and swapping over brackets to install the big cross beam that took the tow bar. I wouldn't know about the L405 I'm afraid.
The FFRR will run rings around any other vehicle for towing duties and can tow 3.5t if you needed it with ease.
It may however be easier / cheaper to find a drop plate to put a normal hitch onto your lightweight. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1059761 7th Feb 2025 9:17am
JW911
As of last week, it’s a late L405. After three L322s, the last one was getting to be a bit long in the tooth to be a daily, hence we’re having this discussion. Funnily enough, the salesman and I both agreed we’d have a 322 instead were they the same age/mileage. Thanks for the thought. Realistically, that is the way I will probably end up going. Also JW911 on FullFatRR
2021 3.0 P400 Vogue
Post #1059763 7th Feb 2025 9:23am
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Just to avoid an awkward moment - are you sure the FFRR doesn`t have a towbar already? They hide them very well when not in use.
A friend of mine did actually book his brand new FFRR in for a tow bar to be fitted and was very embarrassed when the technician pressed the button in the boot and a towball popped out! Don`t drive faster than your angel can fly!
Post #1062615 11th Mar 2025 3:38pm
