Home > Puma (Tdci) > Puma 2.4 Overboost on Motorway
Page 3 of 3 <123
andy63
Well the signal wire at tick over is around what i said mine was but I'm pretty sure mine varied by more than tenths of a voltage under acceleration..
I'm not trying to pee you off..but this is one of the advantages of a scope..
The voltage you are seeing on a multimeter is the result of a varying pulse width on a square wave.. like a mean or rms value , with the scope you can capture and analyse drop outs and behaviour and if you have a known good traces you can identify faults more readily..
Anyway all you can do is make sure the drop out was the result of a dodgy meter connection..
If you want me to stick a meter on mine and see what the varying voltage is on the signal wire with a multimeter I'll try and get that done..
Here is a picture of the reference voltage in blue and the signal voltage in red.in best blue Peter tradition..one i made earlier 👍🤣
Post #1060012 9th Feb 2025 12:00pm
PipsterP10
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi Andy,
You’re not peeing me off, the info you’ve provided has been very helpful. Unfortunately I don’t have a scope but do agree with you that my multimeter is not the best tool for the jibe giving it’s a pulse signal.
I stripped back the cloth tape to inspect the actuator plug wires, no obvious signs of a breakage but then I’ve just been to Halfords to pick up some new cloth tape (only place open today) and it’s giving intermittent underboost and Overboost as well as cylinder pressure errors now including the EGR valve error code. It’s only ever given an Overboost error code so I’m starting to think it’s a wiring issue?
Post #1060019 9th Feb 2025 1:31pm
Ianh
Post #1060021 9th Feb 2025 1:50pm
PipsterP10
I’ll order a new connector, I can only see about 3inches back from the connector due to the foil type inner and plastic outer conduit, both wires for pin 5 and 4 of the connector were bent almost 90 deg as they left the connector body, although the sheave hasn’t been damaged there’s no guarantee the inner wire strands haven’t been damaged.
Post #1060040 9th Feb 2025 4:48pm
jst
did i read its had a new turbo? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060145 10th Feb 2025 7:04pm
Ianh
The OP stated in their original post.
The turbo (standard) and intercooler (Twisted intercooler) were replaced in late 2021
EGR brand new 2 months ago
MAP sensor replaced last month (Genuine part)
MAF sensor replaced last month (Genuine part)
VCV replaced last month (Genuine part)
Turbo actuator brand new (Hella)
Turbo vanes are very free to move with no sticking
Post #1060146 10th Feb 2025 7:17pm
jst
apologies i totally missed that. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060165 10th Feb 2025 9:30pm
PipsterP10
So, I had a bit of time to take it for a run today, watching the MAF sensor data, the g/s varied as I’d expect under load and was up over 100g/s during acceleration. Every time the icarsoft diagnostics records the date at the time of the fault code/limp mode, the MAF data is less than 10g/s this could be because it always seems to be that it goes into limp mode when I’m lifted off the accelerator. Unfortunately my diagnostics doesn’t allow me to log the turbo actuator demand vs actual. So I’m still none the wiser what the fault is, feels like I’m going round in circles at the moment. Banging Head
Post #1060179 10th Feb 2025 10:47pm
andy63
I'm commenting further just for moral support lol.. it difficult if you are not actually experiencing it yourself..
Yo can monitor boost pressure i imagine..so does that confirm an overboost condition or does the map sensor reading drop with maf reading..
I'm wondering what else could cause overboost... restricted exhaust.. exhaust manifold pressure higher than expected , the turbo vanes or actuator sticking..
I remember from your first description I thought some issue with the egr valve as it happened after cruising conditions when the egr should have been active..
And do you have a manifold throttle valve...but I'm pretty sure the map sensor is after that and should record issues with that...
Hope you can get a break and get it sorted...👍
Post #1060199 11th Feb 2025 9:11am
PipsterP10
So, to conclude (hopefully) the Overboost story! I changed the connector for the actuator, although it was still working, as the cables are now longer, they aren’t stressed/bent at 90deg as they exit the connector, so this could eliminate a future problem. To make sure I got a really good solder joint, I made a shallow V notch in a flat piece of wood and used a couple of pegs to hold the joint together when joining the pre-tinned wires, it’s always a pain trying to hold by hand and saves burnt fingers too! The joints were then covered using adhesive shrink wrap to stop any moisture getting in.
I bit the bullet and bought a brand new turbo, although the old one was only 2 years old, it was a reconditioned one. It was fitted today and after a 50 mile dual carriageway run at 70mph no issues with Overboost and limp mode Thumbs Up
I’m going to strip the old turbo and have a look at the vanes to see if there’s any play and how much carbon deposit there is.
Post #1060874 18th Feb 2025 8:54pm
Julie
2 years life expectance for a new turbo ?
Did you get it from JLR or is it a cheap part from the www ?
I'd check if it's still covered by warranty. If not I'd discuss a refund anyway.
Don't exagerate acceleration / revs while driving.
And don't cut off immediately when you were driving at high speed. Let it idle for a while allowing the turbo to cool down
Post #1060880 18th Feb 2025 9:27pm
PipsterP10
It was the previous owner who had the turbo fitted, it was a genuine reconditioned turbo. The new one is brand new from a Garrett distributor.
I do know the company who supplied the reconditioned turbo, I won’t name here as until it’s been stripped to see what the issue is, it would be unfair to say they hadn’t correctly reconditioned it.
Post #1060882 18th Feb 2025 9:46pm
Page 3 of 3 <123
