![]() | Home > Technical > Puma brake pipe size |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
I'm looking at swapping my servo for the abs conversion, tech says it might require two new brake pipes.
The current (plastic covered?) ones measure 4.83mm, I have a roll of uncoated Kunifer in stock that measure 4.55mm - as the seal is on the flared cone formed on the pipe, and there is no coating on the smaller pipe, am I correct in assuming this will be fine? Cheers Keith |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 251 ![]() ![]() ![]() |
3/16 is 4.76mm. perhaps 3/16 kunifer brake pipe would be better? 1953 80"
1987 mini city e 2011 90" |
Thanks, the Kunifer I measure at 4.55mm is labelled 3/16 I think its so close and as it seals on the flare Ill give it a go - we will find out in a couple of weeks!
