![]() | Home > Faults & Fixes (L663) > Fault codes discovered with GAP Tool |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
hello,
first thing, delete them and see if they are still there. Marco |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 242 ![]() ![]() |
Clear them and check a few miles later. All look insignificant tbh MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
As everybody has said clear them and see if they come back, a lot of errors can be triggered due to the battery being low for example. Every time I plug my IID tool in I check errors and just clear them and then check back a day or two later and see if they have reappeared and in all cases they haven't
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3036 ![]() ![]() |
When l first used the GAP tool there were a few like that, an ABS error and something about the 4wd being disabled.
l cleared the fault codes and none of them have ever returned. |
Start worrying when you get these PCM codes and Adblue warnings on the dash
![]() ![]() ![]() Click image to enlarge MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
Eric Caterpillar Member Since: 17 Jun 2024 Location: West of Scotland Posts: 78 ![]() ![]() |
Thank you for your replies, I'll do what's been suggested, plug in a trickle charger and clear the codes.
