![]() | Home > Td5 > AirCon working only on highest fan setting |
JackGilly35 Member Since: 30 Jan 2025 Location: Qala Posts: 2 ![]() ![]() ![]() |
Hi lads, I have a slight issue with my defender aircon.
It only works on the highest setting and been like that since I bought it. Cheers for the help! 2003 td5 XS |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 815 ![]() ![]() ![]() |
Check the switch.... Easy to take apart, as long as you're careful
![]() Click image to enlarge ![]() Click image to enlarge |
Did you have the same problem? and what should I look out for?
I took mine apart to fix the illumination....
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1232 ![]() ![]() ![]() |
There is illumination? Oh
Yup!
Zoom into my first picture and you'll see a little "grain of wheat" bulb... The blue thing in the foreground that is the cover to give blue light 😎 |
